Activity › Forums › Adobe After Effects › jumpy video
  • jumpy video
    Posted by Wayne12345 on August 30, 2007 at 7:14 pm
    I made an AE 7.0 animated video using combination of still photos from photoshop and JPGs. I have rendered it in AE and it looks great. I tried to edit the video and add audio on it in Premier Pro and after I render the final version on premier the video becomes jumpy every one or two seconds and I can see the interlacing lines when it jumps. I have tried several settings on Premier pro without any success. I re-edited the original AE footage on Final cut pro and I get the same thing. after I render the edited video on final cut it will become jumpy and I can see the interlacing lines. I have spent almost a month rendering using different settings on premier and final cut and get the same result. Can some one please help me I will be glad to send a portion the video for you to see what I mean. Thank you in advance.
    Wayne12345 replied 19 years ago 2 Members · 2 Replies
  • Erik Pontius
    August 30, 2007 at 8:04 pm
    What settings are you using to render the file from AE?
  • Wayne12345
    August 31, 2007 at 5:10 pm
    the AE comp settings is as follows:
    Preset= NTSC DV 720×480
    pixel Aspect ratio= D1/DV NTSC (0.9)
    Frame rate= 29.97
    Premier Pro settings:
    Time base code = 30fps
    NTSC = (Drop Frame)
