Activity Forums Apple Final Cut Pro Legacy Jumpy Transitions in Final Cut Pro
  • Jumpy Transitions in Final Cut Pro
    Posted by Ozzy Baines on May 2, 2012 at 1:38 am
    Whenever I put Cross Dissolves or Fade In/Fade Out on the timeline it causes the clip to jump when it’s coming out of the transition. If I export it, will this show up in the final product? How do I fix this problem. I was hoping it was just a glitch.
    Tony Brittan replied 14 years, 4 months ago 2 Members · 1 Reply
  • Tony Brittan
    May 2, 2012 at 11:24 am
    Is your footage from a DSLR or other file based camera and is it used in your project without transcoding it to something edit friendly like Prores first? FCP 6/7 doesn’t like h.264 footage…or basically anything from most file based cams natively. That’s the most common cause of the problem you’re reporting.
    Tony Brittan
    Island Shore Productions
    Pfi
