Activity › Forums › Adobe After Effects › jumpy text seen in scary movies
Posted by Christopher Dykes on October 5, 2007 at 12:49 pmanybody know how to create that jumpy disturbing text seen in scary movies? thanx i appreciate it.
Aza Allen replied 14 years, 6 months ago 5 Members · 7 Replies -
Harry Frank
October 5, 2007 at 1:09 pmIf you can wait just a couple more weeks…
https://www.graymachine.com/content/index.php?option=com_content&task=blogsection&id=6&Itemid=35
There’s a lot of things you can do, but on the position, try this:
probability = 10 ;//higher is less likelyval = random(-probability, 1);
m = clamp(val, 0, 1)
y = wiggle(10, 200*m);
[value[0], y[1]]Harry J Frank
Freelance Motion Designer
graymachine.com -
Steve Roberts
October 5, 2007 at 1:10 pmLike this?
https://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail&loc=en_us&extid=1046739
It’s more of a “project for exploration” rather than a tutorial. It uses the wiggle expression. Hope it helps.
Christopher Dykes
October 8, 2007 at 5:27 pmThis was a great tutorial, I must say. It is exactly what I was looking for. It there anyway to create it for a 16:9 aspect ratio? More importantly I was having a problem with the position expression of the really blurry text layer that jumps around a lot. When I put in the expression for the value of the position it kept moving off the screen instead of being centered. Do you have any tips or suggestions?
Ramon Montes
January 26, 2010 at 5:21 pmHey…did you ever find a solution on how to fix the text from moving off screen? I’m having the same issue and I don’t know how to fix it. I’m using CS3.
Aza Allen
March 9, 2012 at 2:53 amTutorial mentioned no longer works for newer versions of AE… is there another one? – preferably video tutorial…
My portfolio can be seen at http://www.ruesterprod.com
My personal website is http://www.azaallen.com -
Steve Roberts
March 9, 2012 at 3:09 amGoogle “wiggle expression” and “after effects” or try searching youtube for GDM223SR.
Aza Allen
March 12, 2012 at 9:14 pmA wiggle expression only gets you so far… I think what this effect also calls for (At least how I’ve seen it used) is also a part of an expression that keeps the text in one spot for a short time, and then it jumps to another random position within a set amount of space… or, better yet, have the pause interval also be random so it (being the text) would freeze for a moment, then wiggle a bit, then freeze in another position (With varying levels of opacity as well)…
anyone know how to accomplish this?
