Activity Forums Adobe After Effects Jumpy Playback on Encore burned DVD from AE footage
  • Jumpy Playback on Encore burned DVD from AE footage
    Posted by David Payne on September 4, 2009 at 9:33 am
    Hi All,
    I’ve followed an encore authoring guide from videocopilot and have a major problem. I have rendered out an animation with HDV video in the background. I have exported using the MPEG2-DVD preset with progressive fields. When importing into encore lower fields is the only option. When I author and burn the DVD, the footage is jumping/skipping in the background (every second or so)
    I have followed the guide to the finest detail and no one seems to be having this problem but me.
    Does anyone have any ideas?
    David Payne replied 17 years ago 30,081 Members · 4 Replies
  • David Payne
    September 4, 2009 at 2:46 pm
    also, I have burned the dvd in encore using the source footage (without AE getting involved in the process) and it plays back fine, so it must be something I do in after effects…
  • David Payne
    September 6, 2009 at 9:20 pm
    by “something I do in after effects” I meant it was at that stage that the issue occured.
    Ok I’m ashamed as you have given me that stock answer with something in the past. Could you advise what type of file format I need to convert to in order for it to not freak out?
    I wonder why the guy in the guide didnt have this issue as he was importing straight from HDV m2t…
  • David Payne
    September 7, 2009 at 8:05 am
    i should also mention that the footage was only HDV right at the beginning of the chain. I imported HD m2t into premiere and outputted as HD mpeg. Then frameserved this HD mpeg down to a DVD compliant 720×576 PAL mtv and wav, which is the file I imported into AE.
    I then outputted as MPEG2-DVD which I see mentioned in your list above so perhaps that is what I need to change to fix this. I will give this a go now.
  • David Payne
    September 7, 2009 at 9:14 am
    exported as AVI from premiere and now works perfectly.
    thank you so much.
