Activity Forums Apple Final Cut Pro Legacy Jumpy picture in burn
  • Jumpy picture in burn
    Posted by Thom Stromer on August 29, 2006 at 6:27 pm
    howdy- i have exported a FCP QT for burn in DVD studio pro. one shot in the whole piece (which plays at 3 seperate times) gets jumpy for some reason. it is letterboxed and you can clearly see it jumping up and down while on screen. I went back to my FCP project and it doesn’t jump..any idea what this is and how to fix?
    thnaks,
    thom
    Thom Stromer replied 19 years, 12 months ago 2 Members · 4 Replies
  • Mark Maness
    August 29, 2006 at 9:04 pm
    How are you exporting your movie? Are you going thru compressor? If not, it sounds like your fields are getting reversed. I had this problem with Compressor recently. Check on that and see if that doesn’t solve your problem.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Thom Stromer
    August 30, 2006 at 12:03 pm
    i did compress in compressor. how could it affect fields in only 3 instances (of the same shot)? shouldn’t the whole export be off if fields were reveresed?..was your whole export off?
  • Mark Maness
    August 30, 2006 at 2:56 pm
    [Thom Stromer] “i did compress in compressor. how could it affect fields in only 3 instances (of the same shot)? shouldn’t the whole export be off if fields were reveresed?..was your whole export off?”
    No, just parts of it. Yeah, I know… it sounds really strange. But my solution to the problem was to make a copy of the settings in my Custom settings folder and select the encoder tab and made sure that my frame rate was 29.97, the aspect ratio was 4:3, and field dominance was bottom first. Since then, I haven’t seen this issue.
    Wayne Carey
    Schazam Productions
  • Thom Stromer
    August 30, 2006 at 10:31 pm
    wow.strange. i’ll give it a shot. thanks for the advice!
