Activity Forums Adobe After Effects Jumpy Layers
  • Jumpy Layers
    Posted by Robert Keyes on July 17, 2015 at 2:24 pm
    So, when I have a layer, it jumps around when, in my mind, it should be completely still. I know this is a basic thing, but I can’t figure out why it’s even happening.
    Literally only the position changes:
    Position @4s: 1227.0, 540.0
    Position @6s: 1227.0, 540.0
    So, surely the layer should stay where it is, right? The video below is just me messing around, but it’s a continual problem and I don’t quite understand why it’s happening.
    Demo
    John Cuevas replied 11 years, 2 months ago 2 Members · 1 Reply
  • John Cuevas
    July 17, 2015 at 5:23 pm
    You are using bezier keyframes. These ease in & out and it’s causing overshoot in your case. Select the position keyframes, right click on one and choose Linear.
    You can also adjust the movement by opening up the graph window and manually adjusting the ease in and out.
    Here’s some more help… Why does my layer (camera) move back and forth between keyframes of equal value?
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
