Activity Forums Adobe After Effects Expressions Jumping to a specific frame inside precomp when hitting specific position
  • Jumping to a specific frame inside precomp when hitting specific position
    Posted by Saara Salminen on January 17, 2019 at 8:33 pm
    Hi!
    I wish to achieve an expression of the following:
    When the x-position of current layer hits the x-position of layer “Layer2” (the position values are not separated on either layer, if that matters somehow), the time inside a precomp (“Precomp1”) jumps to a specific frame, like frame 30 for example.
    I’m not too familiar with expressions, and this is probably pretty basic, but I’d appreciate any help I can get.
    Thanks in advance,
    Saara
    Saara Salminen replied 7 years, 7 months ago 2 Members · 3 Replies
  • Griffin Englander
    January 17, 2019 at 11:28 pm
    Assuming you only want the frame to be frozen when the positions match.. I think this works.
    a = thisComp.layer("Layer2").transform.position[0];
    b = thisLayer.transform.position[0];
    v = framesToTime(30);
    if (a==b) v else value;
  • Griffin Englander
    January 17, 2019 at 11:29 pm
    Sorry, that expression should go on TimeRemap on your PreComp.
  • Saara Salminen
    January 21, 2019 at 6:52 pm
    This works perfectly, and also makes sense. Thank you very much!
