Activity Forums Adobe After Effects Jumping / Flickering 2d Layers in AE
  • Jumping / Flickering 2d Layers in AE
    Posted by Jerry Renes on August 15, 2010 at 5:32 pm
    Hi All!
    It’s been a while, but I’ve got a question / problem.
    I’m working on a 2D animations, everything went allright untill I rendered it out. Though I have seen this prolem before, now I can’t seem to solve it.
    Have a look at these screenshots / video example:
    https://www.in60seconds.nl/example-01.mp4
    https://www.in60seconds.nl/eyes-comp.jpg
    https://www.in60seconds.nl/daddy-comp-01.jpg
    See the jumping? The mouths and eyes are all over the place. I’m working with Illustrator AI files which have the collapse switch on. The eye / mouths have their own comps (in which I have frames for closed / left / right / open eyes.).
    Then in the main scenes I put the body toghether, so I’m putting the eyes / mouths comps in there, again with the collapse transformation switch on. This is necessary, as I am zooming in sometimes.
    All layers are 2D and zooming is done, by scaling the layers. The other bodyparts don’t seem to flicker on or of / jump. But these are nested / collapse comps as well…..
    I already tried to turn of OpenGL, doesn’t work. Any ideas????
    Help is greatly appreciated!
    Jerry
    Windows 7 – 64 bit
    After effects CS 4
    Jerry Renes replied 16 years, 1 month ago 35,108 Members · 1 Reply
  • Jerry Renes
    August 15, 2010 at 5:47 pm
    FIXED IT ALREADY GUYS!
    Damn that was easy actually……
    I nested the Scene Comps into one big Scene Montage composition. And I didn’t turn on the collapse transformation switch for the scene layers (as I wasn’t scaling them to more or less than 100%) I thought it wasn’t necessary…..
    Turning the collapse transformation switches on just made it work!
    Cheers!
