Activity Forums Adobe After Effects Jumpbacks and AE
  • Jumpbacks and AE
    Posted by Daniel Schloss on September 12, 2008 at 4:58 am
    I have digital juice jumpback HD566 in which a graphic of a frame roatates then stops then rotates. I have been trying to remove the inside of the frame to make it transparent so I can put a video clip in it but cannot get the graphic to erase that particular point AND have it rotate with the frame in the graphic. If I erase the inside of the frame and make it transparent, the erased section will not move when the graphic rotates. Any thoughts?
    Dan Schloss
    info@echomedia.org
    Roland R. kahlenberg replied 18 years ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    September 12, 2008 at 1:21 pm
    Their products are flattened so you don’t have access to the individual layers. Apologies for the self-plug, but take a look at broadcastGEMs’ AE products which are essentially AE project files that give you full access to the layers and is also a great way to learn the software.
    Having said that, youmay be able to to do a corner pin track of the frame to create a matte which you can then apply (the croner pin data as well as the matte) to your video. This one’s tricky and without having seen HD5666, I can’t say if this solution will work.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
