Activity › Forums › Adobe After Effects Expressions › jump to variables from slider
  • jump to variables from slider
    Posted by Mike Roberts on January 29, 2015 at 12:12 am
    hey guys,
    I’m trying to get a null to snap to 4 (or more) positions based on a slider value.
    The script I’m using is this:
    s = thisComp.layer(“COG”).effect(“Torso_Turn”)(“Slider”);
    a = [250,49.5];
    b = [450,49.5];
    c = [380,-30.5];
    if (s <10) linear(s,100,0,a,b);
    else linear(s,0,100,b,c);
    But what i need is for the position to “jump” to the positions instead of sliding to them. What’s the best way to say:
    If s = 0-25 then position “a”
    if s = 25-50 then position “b”
    if s = 50-75 then position “c”
    etc
    is there a simple way to do that?
    Mike Roberts replied 11 years, 8 months ago 2 Members · 3 Replies
  • Dan Ebberts
    January 29, 2015 at 12:26 am
    I haven’t tested it, but this should work:
    if (s < 25)
    a
    else if (s < 50)
    b
    else if (s < 75)
    c
    else
    d
    (you didn’t mention d, but the expression has to evaluate to something (or it will break) if the slider gets above 75.
    Dan
  • Mike Roberts
    January 29, 2015 at 2:31 am
    AH! That makes total sense! I’ll try it out!
    THANKS DAN
  • Mike Roberts
    January 29, 2015 at 9:18 pm
    Just a question out of interest – is there a way for it to work with negative numbers? So if the slider starts at -100 and goes to 100 how would you write that expression?
