Activity Forums Apple Final Cut Pro Legacy jump to marker on the clip (not on the sequence)
  • jump to marker on the clip (not on the sequence)
    Posted by Kozo Okumura on July 12, 2007 at 9:09 pm
    hi, is there any way to jump to the red marker on the clip in the sequence like the green marker on sequence by hitting shit + arrow?
    and is there any way to show the clip marker notes on the canvas like the sequence marker?
    Neil Ryan replied 19 years, 1 month ago 3 Members · 2 Replies
  • Kevin Monahan
    July 12, 2007 at 10:36 pm
    CMD +A, then Shift + M or Option + M. You can see the marker comments only when you go to edit the marker. I just tap M again and read the in the Edit Marker dialog box.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Neil Ryan
    July 13, 2007 at 5:45 am
    [kutmasta] “… by hitting shit + arrow?”
    Personally, I don’t recommend that sort of thing….
    Also, Right-Click (Control+click) on a clip in a timeline will bring up a list of that clips markers. Select one to go to it.
    CAN be useful.
    CAN also be confusing, because it shows ALL that clip’s markers, even the ones outside the amount of the clip used in the sequence at that point.
    Neil.
    Neil Ryan
    Post Production
    The Pod Multimedia
    http://www.the-pod.com.au
