Activity › Forums › Adobe After Effects Expressions › jumbo screen effect
jumbo screen effect
Posted by Chompy on December 17, 2006 at 11:19 amHi folks,can anyone give any tips on re-creating (aka “ripping off!”) the jumbo screen effect rezn8 uses on their FSN spot
https://www.rezn8.com/main_projects_view.php?class=showcase&id=82&count=1&type=movie
I love it, wanna use it, not sure how to go about it.
thanks in advance
chompyC4D R8 (core)
MAC OSX
512 MEG RAMTyler Paul replied 19 years, 9 months ago 7 Members · 9 Replies -
Steve Roberts
December 17, 2006 at 11:46 amIf you’re talking about the disintegrating logo thing on the big screen, it looks like Shatter was applied to one layer of the logo, with other copies of the logo below. Multiple layers were used. Beyond that, there would have been a fair bit of experimentation to determine the right combination of layers shattering and not.
That’s my take on it, anyway.
Mylenium
December 17, 2006 at 7:38 pmYou need to somehow quantize your image and that can be easily done using Card Dance, Mosaic or CC Ball Action. Then apply a grid texture as an inverted matte to get the gaps. How you proceed from there is pretty much up to you, but do not forget that in the clip they use a 3D program and use the footage as a animated texture. You won’t be able to get something as spectacular with vanilla AE.
Mylenium
[Pour Myl
Tyler Paul
December 17, 2006 at 11:07 pmHERE’S what I came up with.
The matte for the screen effect was made from Fractal Noise set to block and the complexity set to 0, then scaled. Then I made a black grid to match it. The gigantic 3D screen was made with multiple layers of the footage. I used an expression with a slider to adjust the curved bevel around the edges.
Place your footage in a comp. Lable it Top. Make a new mask for your desired shape.
Duplicate the Layer. Lable it Bottom.
Add this expression to the anchor point.
thisComp.layer(index-1).transform.anchorpoint-[0,0,3]On your top layer change the mask expansion to -70
Duplicate the Bottom layer and lable the duplicate middle. (Make sure the layers are in order: top middle bottom)
Create a null layer, lable it curve adjust. Add a slider. Set it’s range from 1-2. Lable it Curve.
On the middle layer add this expression to it’s mask expansion
curve=thisComp.layer(index-1).mask(“Mask 1”).MaskExpansion/thisComp.layer(“Curve Adjust”).effect(“Curve”)(“Slider”);
[curve]Now duplicate te middle layer about 15 times and adjust the curve.
“Life Should Come With Backround Music”
-Brown Sugar Studios- -
Tyler Paul
December 17, 2006 at 11:48 pmTake it one step further I just added the mosaic filter to the mix. Now it looks really nice.
In the segment matte I set the fractel noise layer to multiply and placed my footage below it. Then I added the mosaic filter to the footage and adjusted it to match the grid.
Tom J
December 18, 2006 at 1:39 amVery nice, the only thing I would try and do would be to add some sort of subtle frame to the video to hide the duplicates as the camera makes its pass.
Pretty cool and easy too.
Tom
Chris Smith
December 19, 2006 at 5:04 amThe feet momma, the feet! What about the feet!!!???
I love Brak.
Chris Smith
https://www.sugarfilmproduction.com -
Tyler Paul
December 19, 2006 at 1:57 pmWithout audio he looks so evil but then you hear his voice and he’s nothing but adorable.
