Activity Forums Maxon Cinema 4D JUDDER!! Arg!
  • JUDDER!! Arg!
    Posted by Jeremy Kemp on August 8, 2011 at 8:36 pm
    I am having a “Judder” problem with a cinema 4d to after effects project.
    Originally, I had rendered out a psd sequence from CInema 4D at 30 fps and had a lot of jitter or “judder.” I thought I solved the problem when I rendered out my C4D sequence at 60fps. No judder showed in after effects or on export. So, what’s the problem you ask?
    Problem is, most of the stations I am delivering to require 29.97 fps and when I load my 60fps animation in final cut and take it to 29.97, the judder reappears.
    I could really use some advice on this. I’ve read several forums on the matter and most recommendations are to use a higher frame rate. Doesn’t do me any good though when I have to deliver in 29.97.
    How do I avoid this judder if I HAVE to deliver in 29.97??
    Jeremy Kemp replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
