Activity Forums Adobe After Effects Expressions JSON Data expression problem
  • JSON Data expression problem
    Posted by Javier Rodriguez on November 9, 2018 at 6:03 pm
    I’m trying to start the data graph / json tutorial. The original expression to get the country name is this:
    eval(“var x=” + footage(“csvjson.json”).sourceText);
    x[0].name;
    The problem is that i can’t get the “name” thing because in my JSON file their name goes like this:
    “Country Name”: “Mexico”,
    “Country Code”: “MEX”,
    “Series Name”: “GDP (current US$)”,
    If i type “Country Name” I get the expression error.
    How can I get this data witout changing all the names in my file.
    * Same thing with these:
    “1968 [YR1968]”: 29360000000,
    “1969 [YR1969]”: 32480000000,
    “1970 [YR1970]”: 35520000000,
    “1971 [YR1971]”: 39200000000,
    Scott Mcgee replied 7 years, 9 months ago 2 Members · 1 Reply
  • Scott Mcgee
    November 12, 2018 at 12:28 pm
    Json is funny about spaces.
    I would write it like this personally.
    txt = footage(“Country.json”).sourceData;
    txt[“Country Name”]
    The above then allows for spaces.
    Normally if you didn’t have spaces in Country Name like this (Country Name), it would look like this.
    txt.CountryName
    Hopefully that helps
