Activity Forums Adobe After Effects Expressions JSON & Animation
  • Posted by Duane Walters on March 6, 2018 at 5:41 pm
    I’ve been learning how to use the new JSON capabilities in Ae over this past week and while I believe I’ve got the linking down, I’m not sure how to animate them now.
    For instance: I made a line graph, basically a line with nubs for each of the 12 months, I used the ‘points follow nulls’ and all that jazz, and it works great, but how can I animate a point up to the number given in my JSON file?
    I’ve included the script (and a screen shot) for my January point. So how can I animate up to the number my JSON file is giving it, like I would if I were just animating the position with keyframes?
    Are there any good places to learn tasks like this?
    eval("var month=" +footage("LineGraph.json").sourceText);
    temp = month[0].Jan;
    min = 0;
    max = 100;
    max_movement = -485;
    newBaseline = 769;
    myYHeight = ((temp - min) / max) * max_movement + newBaseline;
    [value[0], myYHeight]
    Duane Walters replied 8 years, 5 months ago 2 Members · 2 Replies
  • Kevin Camp
    March 6, 2018 at 11:23 pm
    you could try using linear() or ease() functions…
    try changing the last line to this:
    myYAnim = linear( time - inPoint, 0, 1, value[1], myYHeight ) ;
    [ value[0], myYAnim ]
    that should animate the y position from the original y value to the calculated y height over one second starting at the in point of the layer.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Duane Walters
    March 7, 2018 at 5:46 pm
    Did not work, but I see where you’re going with this, and I’ll further inspect. Thanks!
