Activity Forums Apple Final Cut Pro Legacy JPG colors change upon import
  • JPG colors change upon import
    Posted by Saya Hillman on November 14, 2009 at 7:32 pm
    I have a red/orange/black logo on a white background that upon import into FCP, turns purple/red/black on a blue background, and I’m not sure why? I’d just like it to stay the original colors.
    Any clues most appreciated!
    MAC OSX 10.5.6
    1.8 GHz Power PC iMAC G5
    768 MB DDR SDRAM
    MAC OSX 10.5.2
    2.4 GHz Intel Core 2 Duo MacBookPro
    2 GB MHz DDR2 SDRAM
    LaCie d2 Extreme 160GB 7200 RPM 8MB Buffer
    LaCie Big Disk 380GB
    FCP 6.0.5
    Roel Hugen replied 15 years, 10 months ago 4 Members · 5 Replies
  • Tom Wolsky
    November 14, 2009 at 8:32 pm
    Could you post this graphic somewhere?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • John Fishback
    November 14, 2009 at 9:58 pm
    Might be the graphic is CYMK and should be RGB.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Saya Hillman
    November 15, 2009 at 4:35 pm
    I uploaded the log here: https://picasaweb.google.com/SAHdentist/FCP#
    If it is CMYK and should be RGB, is that something I can change in PS? I have a little bit of PS knowledge and could probably manage that if necessary —
    MAC OSX 10.5.8
    768 MB DDR SDRAM
    MAC OSX 10.5.8
    2 GB MHz DDR2 SDRAM
    FCP 6.0.5
  • John Fishback
    November 16, 2009 at 8:36 pm
    Yes, PS can do it. Open the image then go to Image Menu > Mode and select RGB if it’s CMYK or anything else. Hopefully that’ll work for you.
    John
  • Roel Hugen
    November 2, 2010 at 4:14 pm
    Hi there,
    does anybody now if there is an option to set in FCP studio (Mac) to allow jpegs saved on a PC (and having the PC RGB colour info) to show up in their good colours in FCP.
    Otherwise these jpegs have to be converted in Photoshop as following:
    The solution is to import the Jpeg in photoshop and save as >proof setup > Macintosh RGB. And then import into FCP.
    Thanks for your help.
    Roel
