Activity Forums Apple Final Cut Pro Legacy Jpegs to FCP problem
  • Jpegs to FCP problem
    Posted by Rydenoriginal on September 12, 2007 at 12:29 pm
    Hi All,
    I’m dragging four jpegs into a piece and the first three show up with no problem. The fourth one, while looking ok in the viewer, is nothing but a green box in the canvas. I didn’t change any settings but this isn’t the first time it’s happened.
    Thanks.
    Paul Ryden
    Jason Lyons replied 18 years, 11 months ago 2 Members · 1 Reply
  • Jason Lyons
    September 12, 2007 at 1:40 pm
    Try opening it in Photoshop. If it opens, verify that it is RGB mode open the image there and make sure it is RGB mode under the menu: Image >Mode. It may be CMYK or another format if so change it to RGB, save and reconnect.
    Hope this helps
    j
