JPEGs that won’t import
Hi All,
I’m wondering if you can help with a pretty big problem I’m having with FCP6. I am using v6.0.3 and for no apparent reason that I can think of with the exception of a software update (which also messed up my quicktime conversion), FCP will no longer let me import JPEGs. I do not know if this problem is limited to just these types of picture files or whether the problem is wider spread.
This is what happens:
Open Network Server > Work Folder > Copy JPEG onto External Hard Drive
In FCP – File > Import > Import File
The “Choose File” window opens and the JPEG files are in grey and can not be selected.
There is a dropdown menu that has “Show standard files” which I can change
to “show all files” and the jpegs go from grey text to black and are
selectable.If I select one jpeg file and ask it to import a file, an error box opens
instead which reads:“File Error: 1 file(s) recognised, 0 access denied, 1 unknown”
If anyone has any ideas what is going on I would be very appreciative of your thoughts on the matter.
Cheers!
Sian Fever
FCP Editor, JJ Stereo
