Activity Forums Apple Final Cut Pro Legacy jpegs ping in sequence
  • jpegs ping in sequence
    Posted by Williebondo on November 7, 2007 at 6:44 pm
    Built a montage of stills with a couple of layers. Just imported the jpegs from a folder into a bin. They’re all large jpegs. The stills float thru. Many of them ping and vibrate. Gets worse with rendering. I’ve tried de-interlace and a couple of other things to no avail. Any advice out there. Seems like a new problem. Had to reload software recently and wondering if it’s a sequecne or clip setting.
    thanks in advance.
    Bill
    Rafael Amador replied 18 years, 10 months ago 2 Members · 1 Reply
  • Rafael Amador
    November 8, 2007 at 6:12 am
    You don’t need to de-interlace stills, because stills are not interlaced.
    Don’t edit in a DV time-line. Use a better codec. Also, try don’t use too big stills.
    There is a thread today in this forum about this issue.
    rafael
