Activity Forums Adobe After Effects JPEG sequences
  • JPEG sequences
    Posted by Marc Lucas on June 26, 2013 at 3:07 pm
    Imported a JPEG sequence and got the footage in the AE timeline. Went to do a ram previous of the timelapse and I get a warning saying RAM preview needs 2 or more frames for playback.
    Marc Lucas replied 13 years, 2 months ago 5 Members · 5 Replies
  • William Scholik
    June 26, 2013 at 4:51 pm
    Without seeing your comp I can’t know for sure. My best guess would be that your work area is shorter that 2 frames. Go to the pont in your timeline that you want the preview to start and press “b” then go to the point where you want it to end and press “n”. This will set your in and out points. If this was your issue the it will fix your problem.
    “We cannot solve our problems with the same thinking we used when we created them.”
    ― Albert Einstein
  • Cassius Marques
    June 26, 2013 at 4:54 pm
    Those errors are usualy related to memory issues. Check your footage dimensions, try purging all memory and restart after effects/computer as a last resort.
  • Chris Brett
    June 26, 2013 at 4:58 pm
    — Hi —
    …….oprobably this – check the markers that determine the section of timeline yu are working on — they look like yellow cushions on the grey bar along the top —
    ———————- chris —
  • Todd Kopriva
    June 26, 2013 at 11:24 pm
    What version are you using? 11.0.0? 11.0.2? 12.0?
    After Effects team blog
  • Marc Lucas
    June 26, 2013 at 11:29 pm
    Hi Todd
    CC
    Was there any news on https://forums.creativecow.net/readpost/2/1038663
    Kind Regards,
    Marc
