Activity Forums Adobe After Effects JPEG sequences… How many frames?
  • JPEG sequences… How many frames?
    Posted by Mark Weaver on April 21, 2008 at 12:06 am
    Hello,
    I’m having an interesting issue, actually quite
    frustrating. I’m trying to create an uncompressed
    AVI file from a sequence of JPEGs. There are 2601
    frames in the sequence. Background:
    The frames are generated using C4D and files are on
    a network server.
    I copy the JPEG files to my local HD and import the
    files into AE as a sequence.
    I try to render and frames are messed up, some are
    half drawn, all green, or luminance changes. Worse
    is when AE tells me the file is unrecognized. When
    I look at the individual frame in the windows picture
    viewer, it is clearly broke.
    So I go check the file on the network server and it
    is perfect. I recopy the files and all seems fine,
    but other frames fail. They could be anywhere in the
    sequences, even ones that worked eariler and weren’t
    re-copied.
    So I thought there might be a problem with the copy,
    so I compressed the sequence then copied it over.
    Uncompressing and using these files results in the
    same behavior.
    Finally I broke the sequence into groupings of less than
    500frames. I was able to get something from this, but
    it wasn’t perfect. Still had a few luminance changes,
    but everything rendered.
    Question is, what is the biggest sequence AE can handle?
    Are there specific methods for this. I’ve used 100
    files before and not had a problem. Is there a better
    flow for this?
    I am running AE 8.0.2 CS3 on a XP-sp2 with 3GB of ram
    and 2 internal HDs.
    Any ideas would be much appreciated.
    MBW
    Mark Weaver replied 18 years, 4 months ago 3 Members · 4 Replies
  • Steve Roberts
    April 21, 2008 at 12:42 am
    Hmph. Odd. The number of JPEGS is not an issue, though. I’ve handled longer sequences, but then again … they were TGAs. To be safe, consider rendering TGAs next time. I don’t know why, but …?
    Is there any chance you could import the files from the server, render to a TGA sequence on the local HD, then make an AVI out of that?
    … or just render the AVI using the files from the server? It’s not like you need real-time access, as you would in an NLE …?
  • Mark Weaver
    April 21, 2008 at 1:33 am
    Steve,
    Thanks for the response. I also wouldn’t think AE would
    care about the number of JPEGs. I originally rendered
    TIFF files, but the same issue occured so I don’t think
    it has to do with the files being JPEG.
    You know I thought about just using the server files,
    but I am afraid that AE is corrupting the JPEGs and
    don’t want to destroy these. I guess I’ll have to try
    it since that would tell me if the copy was the problem.
    I’m just hoping to exhaust all other possibilities first.
    Thanks for the suggestions!
    Mark
  • Bryan Bush
    April 21, 2008 at 5:35 am
    Do you have to make it an AVI, that is what I would think is the issue. AVI’s always give me problems some times strange stuff like your talking about. The length of the sequence is not a big deal at all though I have had things over 5,000 frames and it was fine. I was not rendering AVI’s though. Are you interpertating all the footage the same? What AVI compression are you using? I would try a different one, and go through all the files with thumbnails on to check all the frames before you start.
  • Mark Weaver
    April 21, 2008 at 5:25 pm
    Bryan,
    Well I could try to make it a MOV file,
    but I find that AVIs work better on my PC.
    Present case withstanding. At some point it
    has to be rendered to something and I was thinking
    that an uncompressed AVI would be the easiest,
    but you bring up a good point. I’ll try the
    quicktime and see if it is any better.
    Mark
