Activity Forums Adobe After Effects JPEG Sequence w/ RGB mode – “The file format module could not parse the file. (45 :: 35)”
  • JPEG Sequence w/ RGB mode – “The file format module could not parse the file. (45 :: 35)”
    Posted by Dan Schneider on July 19, 2011 at 9:05 pm
    Hello,
    I know that there is a similar thread floating around with a similar title, but my problem was not fixed by it. When I scroll through the timeline, or when I try to export, I get this error:
    I am doing a time-lapse video with JPEG Images loaded as a sequence (footage). I’ve checked numerous times, and all photos are in the RGB mode (the other thread to make sure any and all images were in RGB mode and not CMYK).
    Does anyone have any other suggestions of what might be causing this? OR maybe something that I’ve forgotten to check?
    Dan Schneider replied 15 years, 2 months ago 3 Members · 5 Replies
  • Dan Schneider
    July 20, 2011 at 8:32 am
    (I’ve edited this many times already… I keep discovering new things.)
    I just tried creating a new project and it rendered fine. However, when I tried to add the Timewarp effect like I did in my original project, and scrolled around in the timeline, I gor the error again. I tried experimenting with the speed of the Timewarp, and it seems that the higher I put the speed, the more often I get the error appearing when scrolling around. Below about 110 or so, I never get the error, but staring at 120, the error appears periodically, and at 500 it always appears.
    I can think of no reason why this should be the case.
    Also, I can’t imagine one of the images randomly being CMYK, because they are all from the same camera.
    Any ideas are appreciated!
  • Dan Schneider
    July 20, 2011 at 8:33 am
    (I’ve edited this many times already… I keep discovering new things. Also, if this double posts, sorry about that.)
  • Roland R. kahlenberg
    July 20, 2011 at 9:34 am
    AE handles CMYK issues during import, not after. Take a look at Mylenium’s (ex-COW supremo) AE error code dictionary here – https://aeerrors.myleniumstuff.de/?cat=11 for possible issues and solution(s).
    HTH
    RoRK
    Intensive AE & Mocha Training in Asia.
  • Walter Soyka
    July 20, 2011 at 2:54 pm
    [Dan Schneider] “When I scroll through the timeline, or when I try to export, I get this error: “The file format module could not parse the file. (45 :: 35)” I am doing a time-lapse video with JPEG Images loaded as a sequence (footage). I’ve checked numerous times, and all photos are in the RGB mode (the other thread to make sure any and all images were in RGB mode and not CMYK).”
    I might try Photoshop > File > Scripts > Image Processor to convert the image sequence to another format, then replace the footage with it in AE.
    If Photoshop fails because it can’t read a file, you should be able to tell which one it choked on.
    Walter Soyka
  • Dan Schneider
    July 22, 2011 at 9:29 am
    I’ve now realized what the problem was. For some reason, there were some currupted image files that were at the end of the image sequence I imported. And therefore, when I scrolled around timewarped footage, i encountered the end of the sequence more often. I thought it was random, but it was actually just at the end of the sequence, but I didn’t notice it because it was timewarped, and the end really wasn’t the end. Thanks for all you guys’ help!
