Activity Forums Adobe After Effects JPEG Sequ. Doesn’t Match Original Comp!!!
  • JPEG Sequ. Doesn’t Match Original Comp!!!
    Posted by James Purdie on December 18, 2007 at 11:17 pm
    Wow…this is really irritating. You may know me from my other thread, I waited 24 hours for a ten minute composition of HDV footage plus effects to render. (I failed to mention that on my second attempt I was rendering into jpeg footage in case it crashed again.)
    Anyways, my machine is AMD Dual Core 4200+, 3 Gigs of Ram, AFX CS3
    Here’s my latest irritating news in this continuing saga:
    “The Rebels have hidden on the distant planet of Tatooie….”
    And really:
    After a 24 hour render, my jpeg sequence doesn’t match the same size as the composition from which it came!!!! So how do I get the sound to match??? Should I stretch the comp to fit? I will try it now!! Anyways, the render time is only 30 minutes now. We’ll see!!!
    Aharon Rabinowitz replied 18 years, 9 months ago 3 Members · 5 Replies
  • Steve Roberts
    December 19, 2007 at 12:16 am
    AE automatically defaults to 30fps for imported sequences. Did that happen here?
  • James Purdie
    December 19, 2007 at 12:20 am
    I’m not exactly sure yet. But I did a timestretch to fit the right time. But it goes out of synch half way through. So irritating.
    It’s a new a HDV camera for me. It’s great. It captures all in synch, but on some renders it goes out of synch.
    Hmm….another can of worms it looks like…
  • James Purdie
    December 19, 2007 at 12:29 am
    I reinterpreted the footage as 29.97 like the original and it seems to match up now, whereas before I see it was set for 30. So I’ll see if that makes a difference in the render.
  • James Purdie
    December 19, 2007 at 12:35 am
    Sorry for the lack of info. Originally my composition was HDV size, then I made a new comp 720 by 480 and nested in the original. It crashed the first time I tried to render. So I did a jpeg sequence this time. The pixel aspect ratio was D1/DV NTSC (0.9).
  • Aharon Rabinowitz
    December 19, 2007 at 3:15 pm
    It’s a common mistake. I made it yesterday, myself. I forgot that one of my clients draws animation frames at 24 FPS instead of 30, and I imported the file with AE’s default 30FPS setting. Watch this video for more info:
    https://library.creativecow.net/articles/rabinowitz_aharon/ae_gotchas1.php
    Aharon Rabinowitz
    Email: arabinowitz (AT) yahoo (DOT) com
    All Bets Are Off Productions, Inc.
    Creative Cow After Effect Podcast
    Internet Killed the Video Star: A Guide to Creating Video for the Web
