Jpeg Seq Changed The Resolution
Hey there….there is kind of an irritating issue I noticed here. My composition was apparently too big for AFX CS3 to render into a video. It has 5 HDV GreenScreen Bandmembers on a virtual stage, etc.
Anyways, instead I chose to make a jpeg sequence and the computer appears to be able to handle that. However, the images that came out don’t exactly match the original composition. The funny thing is windows says the images are
1440 by 1080, (the same as the comp and video footage), however the images are suddenly “more squarish like SD TV.” And when I import the footage into the original comp, it doesn’t fit. Like it needs to be stretched out, which distorts it obviously.The export settings were all set to comp size, so I can’t figure it out. Is there a better image file for image sequence renders? Better than Jpeg? What is recommended?
thanks,
April the Patient
