Activity › Forums › Adobe After Effects › Jpeg photo moves are bad-jaggy, stairstepped
  • Jpeg photo moves are bad-jaggy, stairstepped
    Posted by Ed Cilley on July 5, 2007 at 9:12 pm
    Ok, I’ve been doing this sort of thing for some time and now I’m confused. I have some digital photos taken with a Canon camera (8MP) and am doing simple moves on them–zooms, pans. I am adding some other elements (like arrows), or using solids and masks.
    When imported into FCP they are very jaggy or stairstepped. I’ve read Rick Gerard’s pixel aspect ratio article, scanned all the posts–nothing has helped.
    I have tried:
    – Comp size 720×540 Sq pixel, output as same, output as 720×486, output as 720×480.
    – Comp Size 680×486 sq pixel, output as same
    – Comp Size 720×480 Non-Sq, output as same (tried making photo “Fit to Comp” and then move–same thing.)
    – Resizing photos in Photoshop to DV pixel aspect ratio, making the comp DV size also.
    – Both field (lower) and frame renders.
    Using AE7, and taking the comps into FCP 5.12 into a 720×480 DV project.
    What am I missing?
    Ed Cilley replied 19 years, 2 months ago 2 Members · 4 Replies
  • Brendan Coots
    July 5, 2007 at 10:18 pm
    Generally the best way to do photo animations like this is to set up a 720×480 comp, import your pictures, add them to the stage and animate, then output to animation codec 100% quality. With or without fields is up to you, but I always do progressive/no fields.
    If you are doing things this way, you should be golden. It sounds like you might be overthinking the settings and asking AE to do nonstandard things that will cause problems. There is no need to create comps with wacky sizes or worry about square vs. non-square. After Effects is smart enough to handle all the details for you if you just start with a 720×480 comp.
    One word of advice. Unless you are zooming WAY in on your photos, I would not import 8MP images into After Effects. That will consume an unnecessary amount of RAM and resources, and will cause renders to crawl. For most general applications, images of about 2000×2000 are the largest I would recommend, depending on your specific zooming needs.
  • Ed Cilley
    July 6, 2007 at 3:04 am
    [beenyweenies] “set up a 720×480 comp”
    Believe me, I didn’t start making this thing more complicated. I have worked in AE for years, but now I’m going to FCP (vs. Avid) and using still images, and have run into this odd problem.
    So… I took your advice,
    – started a new composition from scratch, (720×480-using the DV preset),
    – resized the 3504×2336 image to 200×1333,
    – added my photo (with one additional layer for the dissolve, nothing else yet),
    – did a small zoom-in (didn’t go past 70% enlargement), and got the same thing.
    Here is a link to a small portion of the clip. It’s full res (80Mb) animation codec, lower field. The problem is the ringing around the metal edges, especially at the bottom between the black and the metal edge.
    https://www.jumpcutpictures.com/Samples/2-4_PS2.mov
    Ed
  • Brendan Coots
    July 6, 2007 at 5:49 am
    Your problem is fairly common with any strong edges that are angled like that, especially on crisp imagery. The problem is that every other pixel of the edge is falling on the next horizontal pixel row down, and as the camera moves in the pixels are hopping down one line of resolution at a time.
    The fact that the image is so sharp is making the problem worse, because the softer the pixels the more they tend to “float” between rows of resolution rather than popping like that.
    I would precomp the animations and add 2px of Fast Blur to them (precomp because 2px blur on that large of an image wouldn’t have any effect), render out your animation and view it on a broadcast monitor via FCP. Adding a small amount of blur like this solves a lot of creep issues and usually isn’t even slightly noticeable once displayed on a set.
  • Ed Cilley
    July 9, 2007 at 4:05 pm
    SOLVED!
    So, I tried several of the suggestions from the posting here, the results were always the same (or worse), jaggy edges.
    I finally started trying small renders and viewing the original QT file. When I turned off “Use Open GL Renderer” the images were sharp and clean. I went back to some original settings, 720×480, lower field, Animation Codec, NO Open GL Renderer, and tried again. Nice sharp edges.
    I am using an Intel MacBook Pro, with AE 7.0. I turned down the amount of RAM usage that AE is allowed to use and solved the other problem I was having–crashes. Life is good.
    Thanks for your help.
