Activity Forums Apple Final Cut Pro Legacy Jpeg jumps when fx applied
  • Jpeg jumps when fx applied
    Posted by Christopher Kinsman on August 11, 2007 at 5:24 am
    Hi and thanks for being gentle. I’m helping on a project and we’re importing a jpeg from photoshop into FCP. When we apply Fade in/out to that jpeg it appears to repo the shot down a couple of pixels but only for the parts of the clip where the fx is applied. This makes the picture appear to jump right after the fade in and right before the fade out. Is there a image size/pixel shape that I should be checking the jpeg for so that it doesn’t do this in FCP? Any thoughts are greatly appreciated. Kind Regards, Chris K.
    Don Greening replied 19 years, 1 month ago 4 Members · 3 Replies
  • David Roth weiss
    August 11, 2007 at 5:47 am
    How are you monitoring? And, are you rendering with “Full” checked in the drop down menu?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Peter Wiggins
    August 11, 2007 at 2:10 pm
    Even though it is a still, try altering the field order or indeed that of your clip.
    Peter
  • Don Greening
    August 12, 2007 at 3:20 am
    As David mentioned regarding rendering your FX: the jumpy picture will go away after you render.
    – Don
