Activity Forums Apple Final Cut Pro Legacy JPEG into FCP
  • Posted by Tectonic on May 1, 2007 at 8:55 pm
    Hi
    I need to resize some JPEG-files in order to use them in a sequence (PAL). Most of them are big and CMYK. So I use Photoshop and do the following:
    -image/mode: from CMYK to RGB
    -image size: from the original size to 720×576 (pixel dimension), ‘constrain proportions’ box unchecked
    -pixel aspext ratio: from square to D1/DV PAL)
    Most pictures look well after this in FCP BUT circles become eggs. So, what am I doing wrong?? I’m not a trained Photoshop user.
    What to do with EPS files ?
    Hope you can help me with this. Thanks in advance.
    Jan
    Amsterdam
    Joseph Mclachlan replied 19 years, 3 months ago 4 Members · 4 Replies
  • Arthur Luhn
    May 2, 2007 at 4:15 am
    check “constrain proportions” you need to retain the image format, resize to 720 and ignore vertical pixels (unless it is less than 576 in which case you will have to resize to larger than 720 so that vertical ends up with 576) and manipulate with motion (motion tab) so that what end up being cropped is what you can afford to lose.
  • Tectonic
    May 2, 2007 at 9:47 am
    Thanks. If I scale or ‘convert’ the pixel aspect ratio in phshop from square to PAL and import
    the file into the browser I see that’s still square (browser columns) and I wonder if I have
    to change it in the browser from square to PAL ??
    Jan
  • Tom Wolsky
    May 2, 2007 at 11:53 am
    If these are flat images, not multi-layer images, just make them 768×576 and leave them square. FCP will handle the pixel aspect conversion.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Joseph Mclachlan
    May 15, 2007 at 8:19 pm
    Hello,
    I was wondering which application you use Motion Tab in. Photoshop or FCP?
    Joe
    17″ PowerBook G4, OS 10.4.6, Final Cut Studio, Photoshop CS2, Canopus ADVC110
