Activity › Forums › Apple Final Cut Pro Legacy › jpeg 100% in Canvas yet blurry/Sharp in Viewer
  • jpeg 100% in Canvas yet blurry/Sharp in Viewer
    Posted by Patricia Magyar on February 27, 2011 at 11:02 pm
    Hi folks, I’m doing a documentary project and am using quite a number of still images. I’ve run into a problem now w a few of them. They are super sharp in the viewer but terribly blurry in Canvas. Perusing earlier posts, I checked Canvas view size and it is 100%. These are images that were originally 8 x10 photos and I thought I would be essentially reducing them and would not run into problem. I went to a site to resize them and that didn’t work (tho I’m not positive I did that process 100% correctly) But then I imported them in their original format, which was a scanned 8×10 photo converted to jpeg. I tried both versions and neither worked. I would be so appreciative if you could help me here. Project is due tomorrow and I hadn’t realized this to be issue until now. (Someone had told me that it is okay if it is blurry in the canvas as long as it is okay in the viewer) I rendered the sequence too and that has not helped.
    Thanks so much
    Rafael Amador replied 15 years, 7 months ago 2 Members · 3 Replies
  • Rafael Amador
    February 28, 2011 at 2:39 am
    And what about your sequence setting, codec, etc?
    rafael
    http://www.nagavideo.com
  • Patricia Magyar
    February 28, 2011 at 2:52 am
    OOops….I just checked the sequence playback quality and it is low. I recall now that somewhere along the line on this project I was told to do that to avoid dropped frames. BUT the good news is that when I raise the level of quality the image in the canvas sharpens.
    Thanks for this
  • Rafael Amador
    February 28, 2011 at 5:05 am
    [Patricia Magyar] “OOops….I just checked the sequence playback quality and it is low. “
    No need to do that.
    Set “Unlimited RT” and Playback Video quality/Frame rate: Dynamic.
    FC will play up to the performance of your system.
    Rafael
