Activity Forums Adobe After Effects Expressions Joining Anchor points to other points on layers (in 3D :-Þ)
  • Joining Anchor points to other points on layers (in 3D :-Þ)
    Posted by Chris Orcfilm on August 28, 2011 at 4:40 am
    So, I know I saw this somewhere before but can’t find it – sorry
    From the diagram below, the upper arm and forearm are (3D) layers
    A is the anchor point for the upper arm
    C is the anchor point for the forearm
    When I rotate the upper arm layer in 3D space, I want the anchor of the forearm (C) to stick to the end of the upper arm (B)
    Of course the B position could be positioned anywhere on the upper arm layer, not necessarily on the bottom right corner.
    Can anyone remember a tut or article describing this phenomenon that is eluding me?
    Cheers,
    Chris
    Orchard Film Studios, Canada
    Chris Orcfilm replied 15 years ago 2 Members · 2 Replies
  • Dan Ebberts
    August 28, 2011 at 5:39 am
    You should be able to position your arm parts so they connect, and then just make the upper arm the parent of the forearm.
    Dan
  • Chris Orcfilm
    August 28, 2011 at 6:53 pm
    Thanks Dan, funny how often you can completely forget the basics when you over-complicate things in your mind. hanks for taking the time. ..as always.
    Chris
