Activity Forums Adobe After Effects Expressions joining an orbit
  • Posted by Geoffrey Amend on March 19, 2012 at 7:35 pm
    I am designing a layout with the following steps:
    1. one circle (with text) in the center
    2. additional circles with text will “shoot” out from behind this 1st element and join a path in motion. There will be seven of these additional circles that will essential form one “orbit” around the center circle…
    Question:
    How do I set the “orbit” and have the additional circles join the orbit in a uniform fashion (that is, they will be placed equal distance apart from one another and at an equal radius from the center object?
    I’m assuming there is some sort of expression control. Right now I have created the orbit of circles and have got it to appear as a ferris wheel (the text remains level while spinning), and now I’m trying to work backwards. I may want to go 3d if I can figure this all out.
    Many thanks.
    Geoffrey Amend replied 14 years, 3 months ago 2 Members · 2 Replies
  • Declan Smith
    March 19, 2012 at 9:25 pm
    One potential method is:
    1. Create a Mask to be the size of your orbit
    2. Click on the Mask Path to select it, then copy it (edit->copy)
    3. Now go to your smaller circle and select position and then paste.
    What this does is paste a bunch of keyframes representing the circular motion path of the mask. You can then adjust the duration this plays out by spreading out the keyframes. You could have a completely different position animation prior to the orbiting keyframe, then ease into it. To have the other circles join is a matter of staggering the layers.
    As this is the expressions forum, I guess its only right to have an expression, but from what you have said, I think the above method may suit better, possible not, but I’ll leave that up to you.
    To create a circular path with expressions, I have included a starter for 10. You would put this expression on the position property of the smaller circle. The First four lines are your variables which can be pickwhipped to sliders etc if needed or you can further derive their values. The radius is the radius of you orbit, the start angle is where on the orbit you want to start (from 0 -360), the speedmulitplier is how long (with that set to 1 it takes 36 seconds), and the centre is the centre of the orbit. I have set this to be the centre of the comp
    radius=300;
    startAngle=180;
    speedMultiplier=100;
    centre=[this_comp.width/2, this_comp.height/2];
    angle = time * speedMultiplier + startAngle ;
    x=radius * Math.cos(degreesToRadians(angle));
    y=radius * Math.sin(degreesToRadians(angle));
    add(centre,[x,y]);
    Declan Smith
    https://www.madpanic.tv
    After Effects CS5.5/ FCS3 / Canon 7D / Canon XL2 / Reason / Cubase
    “it’s either binary or it’s not”
  • Geoffrey Amend
    June 3, 2012 at 6:22 pm
    Thank you very much. I actually figured this out prior to checking back to forums and only now saw the email alerting me to your post.
    Thanks very much.
