Activity Forums Adobe After Effects Expressions Joining 2 nulls with a line in 3d space
  • Joining 2 nulls with a line in 3d space
    Posted by Mark Warner on August 12, 2008 at 10:32 am
    Hello everyone
    I’m trying to join 2 null points, randomly floating around in 3d space, with a simple straight line. The line should move, rotate and scale to line up exactly with the 2 points.
    I’ve tried pointing a solid with a stroked mask at the null but it’s a real pain animating the “End” point of the mask to marry up with the target null.
    Any help would be greatly appreciated.
    Regards
    Mark Warner replied 18 years, 1 month ago 3 Members · 4 Replies
  • Lloyd Alvarez
    August 12, 2008 at 3:44 pm
  • Mark Warner
    August 12, 2008 at 4:14 pm
    Thank you. Really nice solution for 2d! How do I get that z depth in there?
  • Darby Edelen
    August 12, 2008 at 5:31 pm
    [Mark Warner] “Thank you. Really nice solution for 2d! How do I get that z depth in there?”
    You can adjust the size of the line based on how near/far it is from the camera.
    Here’s an updated expression for the start point, end point, start size and end size:
    Start:
    l = thisComp.layer("StartNull");
    fromComp(l.toComp(l.anchorPoint));
    End:
    l = thisComp.layer("EndNull");
    Start Size:
    s = value;
    c = thisComp.activeCamera;
    p = l.toWorld(l.anchorPoint);
    f = c.cameraOption.zoom;
    dist = p - c.toWorld([0,0,0]);
    vec = c.toWorldVec([0,0,1]);
    dist = dot(dist, vec);
    s * f / dist;
    End Size:
    s = value;
    s * f / dist;
    This should give you dynamic resizing of the beam based on its “3D” position. Note, though, that the position expression only works until you pass the camera beyond the Nulls… you’ll definitely notice it when this happens. It might require that you rethink your animation if you had been planning to do a truck in past the nulls.
    Darby Edelen
    NVIDIA
    Santa Clara, CA
  • Mark Warner
    August 12, 2008 at 9:09 pm
    Lovely stuff! I’ll give it a pop but I think your right with the re-think suggestion.
    Many thanks for your time.
