Activity Forums Apple Final Cut Pro Legacy “join through edit” command
  • “join through edit” command
    Posted by Neil Ryan on June 24, 2005 at 3:09 am
    searched the (V4) manual but …
    can’t find how to / if I can
    ‘join through edit’ on multiple edits … as in a whole sequence, at least one track at a time is fine.
    Can anyone help? Is it NOT possible?
    thanks.
    Neil Ryan replied 21 years, 2 months ago 2 Members · 2 Replies
  • John Pale
    June 24, 2005 at 3:39 am
    in your sequence settings you can turn off display of through edits, which may accomplish what you need in a different way.
    Otherwise, the answer is no.
  • Neil Ryan
    June 27, 2005 at 5:43 am
    Thanks John.
