Activity Forums Apple Final Cut Pro Legacy Join Through Edit Audio Glitch
  • Join Through Edit Audio Glitch
    Posted by Innowestern on March 1, 2006 at 8:45 pm
    Has anyone had any problems with small pops and audio glitches on join through edits? The edits with the red bow-ties on either end.
    Lately I’ve been experiencing this. I try deleting preferences as well as changing audio mixing quality to high with no success.
    Bob
    Innowestern replied 20 years, 6 months ago 2 Members · 4 Replies
  • Bouncing Account needs new email address
    March 1, 2006 at 9:11 pm
    Are all of your audio clips and the timeline at the same sample-rate?
  • Innowestern
    March 2, 2006 at 12:31 am
    Some of the clips were 44.1, the DV is obviously 48. There is no overlap of different sample rates where the glitches are occuring.
    I tried to copy just the glitchy part to a new timeline where there is no 44.1 sound based on your advice but it didn’t help.
    Starting from scratch and just making some “join through edits” was clean though
    Bob
    March 2, 2006 at 1:32 am
    Why don’t you “remove” the match-frames?
    Another workaround is to add a 3-frame audio cross-dissolve.
  • Innowestern
    March 2, 2006 at 1:49 am
    That would work except the editor mixed down with the match frame edits in there and the subsequent pops. So we’d have to go back into the premixed down version which is different. We’re patching it now, I just want to make sure it doesn’t happen again.
