Activity › Forums › DaVinci Resolve › JL Cooper installation….
  • JL Cooper installation….
    Posted by Eric Johnson on October 25, 2011 at 4:27 pm
    Just wanted to touch base with people who’ve integrated the JL Cooper Eclipse into their machines, and see what hitches, glitches and fixes they have encountered in the setup of the board.
    I’ve read that getting it running can be frustrating, but once running it is fantastic… can anyone shed light on what they have found?
    Thanks in advance.
    Eric Johnson replied 14 years, 11 months ago 2 Members · 2 Replies
  • Barrie Williams
    October 25, 2011 at 8:43 pm
    You need to make sure you have a network card installed in the jlcooper. Usb or rs232 modules will not work.
    You wil need to set the ip address and port on the jlcooper and again on the prefs page of resolve. I set my port to 50000.
    If connection fails at any time , it will be the port number on the jlcooper which will have spontaneously changed. Just change it back. Its set using a two button combination.
    If you are doing 2d colorwork, the jlcooper is pretty nice, except there is no reset button for the rotary encoders. Don’t attempt to use it for 3D stereoscopic. All the 3d shortcuts which are mapped on the Tangent Wave panel are missing on the JLcooper. That’s not a critcism of JLC… Its DaVinci who decide what is mapped and what isn’t.
    Barrie
  • Eric Johnson
    October 25, 2011 at 8:54 pm
    Luckily I had no issues. All went smoothly.
    I haven’t installed the JL Cooper Ethernet Software yet, was hoping to be able to control FCP with it also.
    Is there a way to change the Luma Ring sensitivity? Right now it has to spin quite a bit just to adjust a tiny amount….
