Activity Forums Apple Final Cut Pro Legacy Jittery Still Frames on DVD
  • Jittery Still Frames on DVD
    Posted by Ronald Thomas on November 7, 2008 at 4:14 am
    Hi all,
    I have a project with a bunch of still frames and after compressing and burning some of the images appear jittery when played back on a regular TV. The strange thing is that not all of the image jitters. For instance, I have a shot of a guy holding a chrome power tool and the guy is rock solid, but the power tool jitters like crazy. It’s very odd. The frames are grabbed from the video, so they’re not a strange format. Is this a compression problem? An interlacing issue? Help!
    RJ Thomas
    Chris Poisson replied 17 years, 10 months ago 4 Members · 3 Replies
  • Bret Williams
    November 7, 2008 at 4:39 am
    Did they not jitter in FCP on your NTSC monitor? It is an interlace issue. You’re just seeing the completely normal movement between the 2 fields that make up a frame. It’s only an issue on the tool because the tool was the only thing moving. You need to put a deintsrlace filter on the freeze frame if of has enough motion to warrant doing so. In this case, you could use a mask to only apply the filter to the area with noticeable motion.
  • John Fishback
    November 7, 2008 at 2:38 pm
    This could also be a field order issue. Check the jittery frames to see if their order (upper/lower) is the same as your sequence’s settings.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Chris Poisson
    November 7, 2008 at 4:23 pm
    Ronald,
    Since it likely is a fields issue, try Fields Kit from revisioneffects.com. It has smart deinterlacers and built in masking. Truly the best deinterlacer out there.
    Have a wonderful day.
