Activity Forums Media 100 jittery rendered graphics
  • jittery rendered graphics
    Posted by Noah Wight on March 4, 2011 at 6:10 pm
    So I’m just finishing up a project that is heavy on graphics. I had to add some movement to still shots and also created a number of graphics with multiple stills moving across the screen. after rendering there is a noticeable jitter in the movement. anyone know how i can smooth this out? i’m on latest suite 1.7 and associated boris.
    Floh Peters replied 15 years, 6 months ago 3 Members · 2 Replies
  • Olof Ekbergh
    March 6, 2011 at 3:32 pm
    Did you add motion blur?
    If not then do.
    If you did then increase the amount. 180 degree shutter is what I use most of the time, (in AE).
    Olof Ekbergh
  • Floh Peters
    March 8, 2011 at 10:46 am
    Do you work on an interlaced or progressive timeline? How do you monitor your results?
    In Boris, you could check the Project Settings to make sure that “better Quality Field Rendering” is turned on.
