Activity Forums Boris FX jittery picture at end of loop
  • jittery picture at end of loop
    Posted by Chrisusvi on April 5, 2005 at 9:54 am
    I have 4 still images that I’m animating to fall into a rack card and each of the four take roughly one full spin before they rest in the rack card the way I wanted them to permanently sit.
    When the movie is played in FCP HD4.5, at the end of the 3 second effect, one of the pictures shivers or jitters like its got a bad coke habit.
    Is there a way to fix the last frame from from jittering?
    Jake H replied 21 years, 5 months ago 3 Members · 2 Replies
  • Scott Fisher
    April 6, 2005 at 5:05 pm
    Have you tried making the effect a few frames too long and and trimming the extra out in fcp? Basically put a hold keyframe on everything, set your prefs to “keep keyframe time” and just make the duration a little longer. This should add some additional frames of the last frame of your effect. I may be 100% wrong but it’s worth a shot ; )
  • Jake H
    April 8, 2005 at 7:35 pm
    I heard this somewhere here and I’m working pretty heavy animating still photos in Boris.
    Use a one pixel vertical motion blur in Photoshop on your original still image before you play with it in BFX to keep it from jittering.
