Jittery Motion on Clips
Hi All,
Sorry I’m new to this forum because I usually work on Windows, but my client is using FCP and we’re running into a problem with some footage supplied from them to us.Here’s the basic signal flow:
[CLIENT]
Capturing DVD via BlackMagic box into FCP using standard PAL DV 25fps settings. Interlaced and Upper Field First.Edited and Exported from FCP as 1920×1080 QT Interlaced (Animation Codec)
[ME]
I’ve taken the QT into AviSynth to resize back to PAL (Lagarith Lossless Codec)HC Encoder VBR 2-pass 7.5Mbps
Once burned to DVD, the video looks really good for the most part, but the client has said there are a few scenes that are very jittery, almost like the interlaced fields should be switched.
According to the client, these clips have been time adjusted in FCP. One is just reversed (-100%) and another has been slightly slowed to (98%)
Is this a known problem in FCP? If so, is there a way to fix on either my side or the client’s? None of these problems are present on any of the intermediate files, only on the DVD.
Many, many thanks for any help!
Clint
Adobe CS4 Master Suite
Vista Ultimate 64 SP1
Intel Core i7 920 @ 3.60GHz
12 GB DDR3 RAM
NVidia Quadro FX 3700
Matrox RT.X2 LE Capture Card
4 TB RAID 5
