Jittery / Jerky video during pan motion
Posted by Brad Miller on December 20, 2010 at 3:38 amHow can I get smooth movement during pans? As seen in the following video, the pan motion is very jittery/jerky. I tried render at 60fps, as well, and it’s still bad. I can create the same video in After Effects and it’s perfectly smooth, but it’s a lot easier to do in Vegas.
Aaron Star replied 10 years, 10 months ago 8 Members · 13 Replies -
Steve Rhoden
December 20, 2010 at 4:13 amJust simply do those kind of motion graphics in After Effects if you have it…Its made for it.
Steve Rhoden
(Cow Leader)
Creative Arts Director and Film Maker.
Project Samples at:
http://www.youtube.com/hentys -
Brad Miller
December 20, 2010 at 4:29 amI understand that… but Sony Vegas Video is supposed to be able to do this. This is just a simple pan motion of one static jpg image. It would nice to be able to do something Vegas is made to do without having to use another program.
Saying just use AE is like saying just use Premiere while I’m at it.
Stephen Mann
December 20, 2010 at 3:07 pmshow us the Vegas results. I’ve done this in Vegas with no jerkiness.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Brad Miller
December 20, 2010 at 3:23 pm -
Guillaume Jeffrey
December 21, 2010 at 8:23 amI ran into the same problem some time ago.
The only workaround I found was slowing down the pan and add a slight motion blur to the event. -
John Bolton
December 21, 2010 at 4:03 pmThe way I overcome it was to make the project with the frame rate @ 100 FPS ( or any higher number ) , None Progressive scan – Blend fields and then the timeline images set Reduce interlace flicker and Non Progressive and render as None progressive with 60 FPS and it is very smooth. Using standard FPS in the project is jerky. Worth a try for you John
Brad Miller
December 21, 2010 at 4:20 pmI’ll give that a try. Good idea.
Once you rendered it at that frame rate, and added the rendered clip to a 30fps project, was it still smooth in the final project?
John Bolton
December 21, 2010 at 4:58 pmHi there .. I added the MPEG file to a video which was @30FPS and rendered again and it ws still looking OK.
Luke Adams
January 3, 2011 at 1:53 pmHey, I am having the same issues. I have a project that consists entirely of jpegs in Sony Vegas Movie Studio, and some of my pans/zooms seem to jitter or stutter somewhat. Did anyone figure this out yet?
Brad Miller
January 3, 2011 at 3:53 pmUnfortunately I have not, so I’m sticking with Adobe After Effects.
