Activity › Forums › Apple Final Cut Pro Legacy › jittery graphics
  • jittery graphics
    Posted by Angela Forster on February 27, 2006 at 11:03 pm
    i have a series of stills that have alpha channels in them. they exist in several different layers. as i move them independently and view them once rendered, they jitter up and down roughly 2points in both directions. this visual occurs in both the NTSC world and on a computer monitor.
    i have no compression on the sequence. i have selected lower field dominance and have applied motion blurs to all of the cut out images. the images are all photoshop files.
    any idea how to smooth out the motion so that i don’t get this jitter?
    thanks a million.
    a.
    Angela Forster replied 20 years, 7 months ago 3 Members · 3 Replies
  • Kevin Monahan
    February 28, 2006 at 12:37 am
    Have a look in the video monitor. Are you still seeing the problem? You can’t judge rendered graphics without an external monitor. The Canvas displays a much lower quality than what is reality.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Eli Mavros
    February 28, 2006 at 3:47 pm
    Try the deinterlace filter…also the flicker filter sometimes helps, but mostly with type I think. But I have seen this myself, and solved it with these two toys.
    Best,
    Eli
    Eli Mavros
  • Angela Forster
    February 28, 2006 at 3:59 pm
    thanks for both suggestions. the jitter of the images occur on the monitors at the station that my work gets sent to. they aren’t font, they are cut out photographs. i’ll try the de-interlace as well.
    i appreciate your time.
    sincerely,
    a.
