Activity Forums Adobe Premiere Pro Jittery footage
  • Jittery footage
    Posted by Omnidecay on October 27, 2007 at 5:45 am
    I am trying to capture from a Sony HDR-FX1 using CS3. When I do this, the image seems to be coming through Premiere Pro slower than what is playing from the camera (almost like the monitor is echoing what the camera display is showing).
    I even tried just playing normal (without recording) and it still has a delay in Premiere. This was happening to me in AVID as well. The result is a jittery, over all bad capture! Has this problem happened to anyone else? How do I fix it?
    Brennan Wright replied 18 years, 9 months ago 3 Members · 2 Replies
  • Vincent Rosati
    November 6, 2007 at 1:59 pm
    If you are watching the cam monitor as you capture, it’s normal to see a slight delay in your capture window. As far as the jitter, I’m unsure.
  • Brennan Wright
    December 2, 2007 at 1:09 am
    capture then play it back. i shouldn’t be “jittery”
