Activity › Forums › Adobe Premiere Pro › Jittery footage from DSLR – unable to solve
  • Jon Doughtie
    February 5, 2015 at 2:23 pm
    Is your footage stored and [playing back from the system drive – that is, the same drive on which your edit software is located?
    If so, this is a big no-no which may be the root cause, or is masking the real root cause of your playback problem.
  • Henrik Duncker
    February 5, 2015 at 2:59 pm
    No, it is on external FW disk.
    But I also have tried to play from the start-up disk and several other externals while looking for a cure.
    Henrik
  • David Baud
    February 6, 2015 at 12:09 am
    What was your shutter speed setting when recording these clips? does the Nikon let you change it in video mode? if so I would try to slow it down. If not you can recreate the motion blur in post using a plugin like the Revision FX RSMB.
    David Baud
    Post & VFX
    KOSMOS PRODUCTIONS
    Denver – Paris
    http://www.kosmos-productions.com
  • Kevin Monahan
    February 6, 2015 at 12:10 am
    Hi Henrik,
    What happens if you change the extension from .mov to .mpg? This helps a lot of other Nikon DSLR users.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Henrik Duncker
    February 10, 2015 at 6:19 am
    Hi Kevin,
    Changing the extension from .mov to .mpg only causes QuickTime to start a conversion process if I try to play the movie (i.e. it wont play the file as such).
    Best
    Henrik
  • Henrik Duncker
    February 10, 2015 at 6:33 am
    Hi David,
    I used as long (or almost as long) exposure times as the camera allows for a given frame rate. I do recognize that using a 1/60 shutter speed with 60fps may not be ideal and can cause too much of motion blur. Unfortunately I did not make notes on the shutter speeds used when I shot the actual footage I started working with, nor did I make notes on my first pendulum tests. However I certainly did not use too short shutter speeds, wanting to avoid strobe like effects. Further, I recognize that when working with slow motion effects (like in my case) the shutter speed / frame rate relation may need extra consideration.
    Nevertheless, I have now got enough feedback from people who can’t see any frames dropping (stutter), so that I can quite safely assume that the camera is fine, and so are the files that I’ve produced. What remains is the question why my computer is giving the hick-ups. System upgrade to Yosemite and possible further talks with Apple are the next steps.
    Anyway, thanks for the input. I will take the linked pendulum test offline as it won’t serve a purpose any longer.
    Henrik
Page 2 of 2
