Activity Forums Adobe After Effects Jittery Camera Moves
  • Jittery Camera Moves
    Posted by Daniel Elder on July 9, 2008 at 9:22 pm
    My camera move is causing jittery movement at times for my pictures and the background, I’ve rendered out 10 different moves, adjusting the camera in many different ways, and nothings working. I’ve played with interlacing, reduce interlace flicker, blurring, and nothing. Could someone please advise me on something I’m missing???
    The move is a simple pull out from an image to a table top of about 18 images, the camera pans across the images very slowly over the course of 22 seconds. Thanks for any advice.
    Daniel Elder
    producer
    http://www.luminair.com
    Daniel Elder replied 18 years, 2 months ago 2 Members · 5 Replies
  • Daniel Elder
    July 9, 2008 at 9:45 pm
    That did work, rendering it out with Sorensom 3 right now. Will update shortly, thanks Dave
    Daniel Elder
    producer
  • Daniel Elder
    July 9, 2008 at 9:59 pm
    I still got some jitters in the camera rendering with Sorensom 3, will try some of the other routes suggested, unless you have any other ideas?
    Daniel Elder
    producer
  • Daniel Elder
    July 10, 2008 at 4:19 pm
    I tried to simplify my move, and that didn’t do anything to resolve the jittery camera move. It happens every 4-5 seconds and it’s the whole camera that jitters. What should I do?
    Daniel Elder
    producer
  • Todd Morgan
    July 10, 2008 at 5:26 pm
    Do you have any keyframes located at those jitter points for any of the camera’s transforms?
  • Daniel Elder
    July 14, 2008 at 5:16 am
    I didn’t at any point, it was happening in between keyframes, now I even simplified the move to a straight move and it’s still jittery? Not sure what to do, the move is simple, the images are stationary, I don’t know if the file size is too large, but that doesn’t seem like it would be the case.
    Daniel Elder
    producer
