Activity › Forums › Adobe After Effects › Jitter/Stutter fx like “The Ring”
Posted by Speedyman on July 30, 2007 at 4:49 pmHi all you experts! (hope this flattery helps to get a response)
I’m not sure if this is the right forum, but I think AE can do the effect I’m after.
I want to mimic the VFX seen in the movie “The Ring”, where the girl walks with a jittering-like gait. This same effect was recently used in a Mercury Mariner hybrid commercial: https://www.mercuryvehicles.com/extras/tvads.asp
The commercial was done by “The Brothers Krause” at hydraulx: https://www.hydraulx.com/commercial.php
I think time-remapping could work, but I’m sure there are subtleties I’m missing. Anyone done anything like this before, and how to approach it? Or maybe Jill Wagner just normally walks this way (just kidding)?
Chris Vile replied 12 years, 4 months ago 12 Members · 13 Replies -
Steve Roberts
July 30, 2007 at 5:42 pmTime-remapping would do it, but you’d probably want to apply an expression to it rather than manually keyframe it. An expression that would allow you to use a slider to set the skip interval and skip amount would be great, but it’s beyond my abilities at this point.
Maybe post in the Expressions forum?
Jerzy Drozda jr
July 30, 2007 at 5:57 pmHey!
glad you are wanting to achieve that effect. i just made a great pseudo-plugin for after effects, and its free of course. i’m planning to post a tutorial on how to use it.
stay tuned. it will come this week.
maltaannon.com – Free After Effects Video Tutorials and more
Speedyman
July 30, 2007 at 6:54 pmThank you. Your website is very informative! I had not seen it before. I’ll stay tuned for your tutorial.
Mike Clasby
July 30, 2007 at 7:56 pmLooking forward to Maltaannon’s tut. The snake was very nice.
In the meantime, Andrew has a Speed Change Tut, here:
https://www.videocopilot.net/videotutorials/timeremap/index.htm
Andrew sets Time Remap keyframes, then slides two together where you want them to speedup. Also grab the ones to the right to keep the following keyframes at the same relative time.
If you keyframes one cycle of Time Remap (so to speak), so enable Time Remapping, set three keyframes, one at the inpoint, then at 1 sec and a third at 2 sec, then if you drag the third keyframe to the left, leaving it next to the middle keyframe, it will speedup there. Then Delete the Time Remapping keyframe at the end of the comp (so now you only have those three keyframes at the beginning) and add this loop expression to Time Remap:
loop_out(“offset”,0)
It adds the values cumulatively so you’ll continues on in time, but they’ll be a speedup every 1 sec.
I think your better off keyframing the remap-speedup as Andrew does in his tut, so it will match the footage better, but that expression will give you a periodic speedup.
This methods really messes with the sound, you get a speedup-hiss…
David Bogie
July 31, 2007 at 5:47 pmWe’ve been bashing this same topic about over in some FCP forums. The problem isn’t getting the time to remap–that’s easy. The problem is in shooting the footage.
Our brief experiment is inconclusive but it implies that you must have athletic and very patient talent. We asked a model to walk v-e-r-y slowly, about 1/3 normal speed and simply ramped the footage x3. The effect was kinda creepy. However, it was painfully obvious that, like all good visual effects, the results are directly proportional to the amount of research and planning you do LONG before any camera rolls.
bogiesan
Speedyman
August 1, 2007 at 11:14 pmI hear ya. Athletic and patient talent? What, next you’ll suggest I pay the talent. haha! Well, thanks for the response. This is looking a bit more complicated than I imagined.
BTW, I think the model in the Mercury commercials is Jill Wagner. I don’t know how patient she was during filming, but she does look plenty athletic to me. raaawwrrr!
Vfx Umair
August 7, 2007 at 7:22 amHey Dude!
when i open the page of maltaannon.com its not responding dear one day before i was opened it in that time it was working but right now when i go via maltaannon.com link its not working. Is there any problem or are u updating your site?
waiting for your reply.
Regards,
Umair
Student of AE VFX -
Jcsfx710
August 8, 2007 at 5:27 pmi guess i would like to add my 2 cents of information in regards to this effect, i was watching the making of a scary movie called the messengers and in one scene the kid crawls on the ceiling in that same style and in the making of featurette the technical director stated that it was shot at 6 frames per second and i know that after effects comes with a plug in which can cut frames, so give it a try and let me know if that would work.
Andrew kramer has a tutorial on frame rate conversion maybe that can start you off here’s the link. https://forums.creativecow.net/articles/kramer_andrew/fps/index.htm
where he has some presets and i believe the name of the plugin that would allow you to do that in AE is posterize time.so there you go, hope this helps some.
JC -
Jim Wilson
August 13, 2007 at 1:38 pmMy thought about these Car spots has been that they actually shot the talent walking backwards. This would be similar to the crypt scene in Coppola’s Dracula where they had the vampire girl walk backwards up the stairs and then ran it in reverse – same creepy results – less plug in.
Christoph Smaid
August 12, 2008 at 3:57 pmhey guys,
tried to install this preset but i got this message: “5 invalid procedure call and argument”. downloaded visual basic library too, so do you know whats wrong?
cheers, chris
