Activity Forums Apple Final Cut Pro Legacy Jitters when Converting Final cut project to quick time
  • Jitters when Converting Final cut project to quick time
    Posted by Thegunnerysucked on September 14, 2007 at 4:09 pm
    I cant make an hdv 24 p project convert to a quicktime
    or dv stream without getting a few jittery frames
    it seems to happen in the same spot everytime no matter which
    conversion setting I create. open to suggestions.
    Ive converted far more complex projects easilly, why is this so tough? it is an hour long project where the last project was 18 minutes long.Mabey that would make a difference.
    Colin Mcquillan replied 18 years, 11 months ago 3 Members · 8 Replies
  • 8 Replies
  • 13 Create COW Profile Image
    13
    September 14, 2007 at 4:22 pm
    Well you are going to have to tell us how you are going about doing it, for anyone to be able to help.
  • Thegunnerysucked
    September 14, 2007 at 5:27 pm
    Export to quicktime,ive tried all kinds of settings
    such as fast , medium and slow streaming settings
    dv stream, 16×9
    24 frames ps
    im just trying to create a small project that works without the jitter at this point, I would like to create ideally an emailable file.
    13
    September 14, 2007 at 5:30 pm
    Try Compressor.
    Video is big I never recommend emailing it, because you do not know if the other persons email can handle a file that bit, better to post it online and email a link.
  • Thegunnerysucked
    September 14, 2007 at 6:32 pm
    I will post on brightcove, what do you recomend I use as format to post to that?
  • Colin Mcquillan
    September 14, 2007 at 6:48 pm
    from compressor for client review I like the web download H.264 800kbps preset. file size is approx. 295.31 MB/hour and maintains full frame rate. If full frame rate isn’t a concern and dropping down to 15 frames a second is OK, the H.264 300kbps preset is nice at approx. 96.68 MB/hour. I’d stay away from this though if you have a lot of flashy cuts and fast transitions.
    Colin McQuillan
    Vancouver BC
  • Thegunnerysucked
    September 14, 2007 at 11:40 pm
    web download eh, never did that before, how do i do that?
    thanks,
    Paul
  • Colin Mcquillan
    September 16, 2007 at 8:24 pm
    export using compressor, once in compressor, navigate through the presets.. off the top of my head i thinks its…. apple -> other workflows -> web -> download -> voila!
    Colin McQuillan
    Vancouver BC
  • Colin Mcquillan
    Colin McQuillan
    Vancouver BC
