Jittering in 3D shot
Hi there,
I have a question about 3D in After Effects. Every now and then I get ‘jittering’ on artwork layers when I do even simple camera moves.
This happens mostly with artwork that has fine detail eg. a grungy texture, and seems to be more prevalent when layers are oriented at 90 degrees to the camera (lying flat).
I haven’t been able to find a way to fix this, and usually I’m forced to use a different piece of artwork which isn’t ideal.
The strange thing is that it’s not consistent. Some finely-detailed, lying-flat layers render just fine with no jittering whatsoever.
Does anyone have any ideas how to solve this problem?
Would be appreciated. Thanks,
ALEX
