Activity Forums Adobe After Effects Jitter on time remapped footage
  • Jitter on time remapped footage
    Posted by Shanu Shukla on May 6, 2009 at 6:05 am
    I am time remapping a 13 sec HD (progressive) footage to 7 sec, and then rendering it using frame blending but i am getting a lot of jitters on playback.
    Any pointers will be highly appreciated.
    Mikkel Sørensen replied 12 years, 4 months ago 3 Members · 3 Replies
  • Justin Vaillancourt
    May 6, 2009 at 12:51 pm
    If you’re speeding footage up, you shouldn’t need to use frame blending because you’re removing frames, not creating them. You can also try using the pixel motion setting by turning the frame blending to best quality.
  • Shanu Shukla
    May 7, 2009 at 1:34 am
    thanks for your response justin, but I have tried that option.
    It could be that converting the original HD @ 50fps to 25fps in after effects is causing this problem?
  • Mikkel Sørensen
    April 9, 2014 at 6:21 pm
    I have the same problem. Even though i make the clip after ( removing frames), it gives a slight jitter on playback. Wow okay so this post very old…. any solution?
