Activity › Forums › Adobe Premiere Pro › jitter on dvd
  • jitter on dvd
    Posted by Andrewe2 on February 12, 2007 at 6:44 pm
    I’m fairly new to dv editing and just tried burning a dvd from PPro 1.5. I used NTSC high quality – force max bit rate – 2 pass and am seeing a lot of jitter on playback on a TV in scenes with motion or pans.
    I wonder if there’s a problem with the source – I copied 8mm tapes to dvds using a dv link to dvr. I then took analog out of dvr passed through camcorder with dv out going to computer for capture.
    The computer should be able to handle it – 3.6 GHZ 2GB Ram 16x NEC dvd burner.
    I haven’t played with interlace settings, should I?
    Any ideas or suggestions?
    Andrew
    Andrewe2 replied 19 years, 7 months ago 2 Members · 4 Replies
  • Vince Becquiot
    February 12, 2007 at 7:21 pm
    It’ s probably a reversed field order.
    Vince
  • Andrewe2
    February 12, 2007 at 8:13 pm
    Apologize in advance if this is a silly question but is that easy to correct and/or learn how to do?
    Thanks for the quick response
  • Vince Becquiot
    February 12, 2007 at 8:33 pm
    I will assume here that all clips have the same field order. If you use the Adobe media encoder to export, just go to the video tab and change the field order to upper (Lower is the defailt setting). See if that helps.
    Vince
  • Andrewe2
    February 13, 2007 at 7:38 pm
    Reversing the fields seemed to do the trick. Thanks for your help!
