Activity Forums Apple Final Cut Pro Legacy jitter issues in fcp only
  • jitter issues in fcp only
    Posted by Jack King on August 10, 2010 at 2:08 pm
    Hi there,
    just to quickly let you all know this isn’t about smoothing out camera jitter!
    I have 2 HD prores mov files in quicktime that play fine. I’ve converted them both to prores lt and imported into fcp, to find that the image is a little jittery. It doesn’t seem to play back as smoothly in fcp as it does in quicktime – which i’d be fine with if it went back to being smooth on export – but it doesn’t!
    The biggest problem is with my 7d footage, which was shot at 50fps and i’ve slowed it down in cinema tools to 25fps. Again, when i play this as the converted mov quicktime, it’s quite smooth – but when put into fcp, it starts to jitter, and the problem is now there on export.
    The other file is 16mm footage, which is also fine as a tk’d mov quicktime, but when played back in fcp (as prores LT) some of the frames seem to get caught.
    Really annoying!
    Can anyone help???
    Jack 🙂
    Michael Gissing replied 16 years, 1 month ago 3 Members · 2 Replies
  • Mike Throck
    August 10, 2010 at 8:02 pm
    Could be a field dominance issue, have you checked the sequence settings against your footage?
  • Michael Gissing
    August 10, 2010 at 9:40 pm
    What are you sequence settings and how are you monitoring?
