Activity Forums Apple Motion Jitter Background
  • Jitter Background
    Posted by Randy Rohde on May 10, 2005 at 4:59 am
    I’m creating a simple text over a background, but once I exported it I noticed that it jittered. If I go frame by frame the image moves around. Is there a solution to this?
    Doyle Rockwell replied 21 years, 3 months ago 3 Members · 5 Replies
  • Randy Rohde
    May 10, 2005 at 5:11 am
    The background is a partical emitter. It’s not a static image. I should have specified that.
  • Richard Harrington
    May 10, 2005 at 11:51 am
    You have interlaced material and thin lines…
    Make the object bigger….
    OR Apply a slight vertical blur
  • Doyle Rockwell
    May 10, 2005 at 5:42 pm
    Hey Randy,
    This particle background…does it have a filter applied to it?
  • Randy Rohde
    May 10, 2005 at 10:50 pm
    Yes several Directional blur, contrast and crystal thing… It doesn’t jitter constently just sparatically. Like a spastic object in bursts.
  • Doyle Rockwell
    May 11, 2005 at 5:00 am
    Hey Randy,
    It sounds like you’re running into a size problem. The particle object constantly changes size, so if you apply filters that have a centerpoint, like Zoom Blur, etc, the centerpoint jumps around, causing the image to jump around. Motion 2 allows you to hard-set layer sizes, so you can set the layer with the particles in it to a specific size and the filters won’t cause jumping. In Motion 1, you can just put a transparent color solid generator in the background (that is larger than the largest size the particles get) and apply the filters to the parent layer. The generator acts as a “spreader” and makes sure that the layer’s size stays constant, and your filters stay stable.
    Hope this helps.
